03 mazda protege Bad turbo question ?
Old Nov 26, 2010 | 06:28 AM
D2R's Avatar
D2R
Default 03 mazda protege Bad turbo question ?
Hi guy just today when I was driving my car I decided to go pass 5000rpm to hit boost but for some reason it started to jerk back when i was going pass 5000rpm could it be that the turbo going bad or is it something else I should look at please let me know if you had experience the same problem befor thanks the car is all stock.
Old Nov 26, 2010 | 02:26 PM
D2R's Avatar
D2R
Hey guys does anyone here know where this rubber line go to or has a turbo diagram for a 03 mazda protege turbo ? please let me know thanks. the picture is taking at the bottom of the turbo
Old Nov 26, 2010 | 06:37 PM
wsoape281's Avatar
that is the vacuum line that goes to the waste gate actuator. it needs to go to a nipple on the front of the cold side turbo housing.
that is probably what the problem is. replace that line and look into putting a one way check valve in to keep only positive pressure on the waste gate actuator. vacuum pressure is bad for the actuator.
Old Nov 26, 2010 | 07:20 PM
D2R's Avatar
D2R
Thanks for the info Is there a picture that you can show me where it should go
Old Nov 27, 2010 | 12:00 AM
wsoape281's Avatar
i am actually mistaken here. on the mazdaspeed protege, the vacuum for the WGA goes to the intake manifold. the wastegate actuator (WGA) is the thing to the left, inside of the yellow circle on your pic.
i have been looking for a pic of this and i can't really find anything for you. if memory serves correctly, the line should plug into a nipple on the top of the intake manifold. just look for a loose line up there and see what you can find.
Old Nov 27, 2010 | 11:36 AM
D2R's Avatar
D2R
I looked all around my intake manifold can't seem to find where the vacuum line hook up
Old Nov 28, 2010 | 10:32 PM
wsoape281's Avatar
where are you located?
Old Nov 29, 2010 | 08:51 PM
D2R's Avatar
D2R
Plano, Texas why?
Old Nov 30, 2010 | 04:26 PM
wsoape281's Avatar
i just had a feeling. i am in houston tx. this is the only time that i ever plug other forums here. www.dfwmazdas.com will be a good place for you to sign up. if you bought your car second hand, you may have bought it from someone off of there.
that is a good group of guys and they always get together to work on each other's cars. let me know what those guys say and if they help you out at all.
Old Nov 30, 2010 | 06:38 PM
D2R's Avatar
D2R
Just tee the line to the bov back to the Intake manifold
