'01 Protege 1.6L engine "bucking"
New to the group and need some help trying to diagnose a problem with my 2001 Protege 1.6L. A few weeks back, the engine was "bucking" (loss of power) at high engine rpm. I removed and cleaned the EGR valve and the problem was solved until now. Now the problem is more severe and any engine rpm speed and causes the engine to stall as well. Any help would be appreciated!
engine bucking
Check the air intake hose carefully for cracks and leaks. I have had 3 "accordian like" intake hoses crack and leak on Proteges causing randon engine "bucking" . If the hose is cracked - just duct tape it together until you can order a new intake hose. A leaking hose causes the mixture to lean out.
Originally Posted by KRN
(Post 129168)
DAMN THREAD SORT is Alphabetical
2 Attachment(s)
Originally Posted by tradosaurus
(Post 129478)
Wow! A response to a 5 yr old post. I wonder if the OP is still alive? :)
I still find value in the old posts and I read and respond to any relavent posts I find. There are still many Proteges out there and I strongly suspect this problem gets worse with age. Keep those Proteges alive and well!
Ticking sound in engine
(Post 129482)
