00 Protege cruise control
My 2000 Mazda Protege's Cruise Control is not working.,.,.i noticed that today.,.,.,it was working 1 month ago.,.,now when i just switched on the cruise control,.,.,the light does not indicate it.,.,,does anyone know wut will be the possible reson to it?
too anybody having this problem still... I read it was the clock spring inside the steering wheel. If your horn is not working either... this will most likely be your problem. I still have to repair mine, i will try this and i will let you guys know. Thanks.
Check if your horn is not workin either. if so. You have to replace the Clock Spring. Its located behind the steering wheel.. you take off the airbag( unplug negative cable from battery, wait 1-2 min) then wen its removed you can see it , its had a yellow sticker around it. but you will have to completely remove the steering wheel. hope that helped. I fixed mine jsut today.
brodrick
Jun 6, 2006 12:59 AM
