fender removal?
Old 09-25-2008, 03:53 PM
BikerA's Avatar
Default fender removal?
I found 4 bolts on top of the fender, 2 on front, 1 top rear, 1 bottem rear and it will not come off. What's holding it?
BikerA
Old 09-26-2008, 08:54 PM
Default RE: fender removal?
There should be 5 on top i assume this is the bolt u missed it is under the window wiper "cowl" to take it out pop all weather strip off the cowl and simply pull on the cowl it should come off with a "pop" then pull it over the wipers if your truck is like mine turn on your wipers then shut them off a the highest part of their stroke andturn off the key wierd way of doin it but it works then pull the cowl off and undo your bolt, their are two on the front, oneonthefront inner wheel well two on the lower rear of the wheel well and one in between the door hinge for an overall of 11 bolts oh i hope you have b2200 style body other wise this was a usless post
rspi
07-01-2013 09:28 PM
garrettbung
06-02-2011 02:53 PM
ian.fisch
12-01-2010 11:44 AM
djpillers
01-24-2008 12:42 PM
CP Racing
12-16-2003 04:07 PM
Quick Reply: fender removal?
