Clutch problem plz help
Old 02-12-2018, 09:33 PM
Zjevans's Avatar
Unhappy Clutch problem plz help
Hey guys just bought this car I'm gonna pick it up in 2 days. But the guy I got it from reckons clutch has gone in it. He says I can drive it I just gotta start it in gear and drive it home without clutch
he says if u put the clutch in nothing happens
it's a 1997 Mazda b2600 petrol 4x4
Old 02-13-2018, 07:51 AM
Cusser's Avatar
What country are you in? Anyway, the Japanese-made B2600i was last sold in USA in 1993, but continued on in worldwide (I'm saying you are fortunate).
Anyway first explore the clutch master and clutch slave cylinders, they seem to malfunction every few years on these trucks. Have a helper push down the clutch pedal a few times and go underneath and look at the little arm on the side of the transmission, see if the hydraulics make that arm move about 12mm each time the pedal is pushed down.
Typically, when the clutch itself wears out, the truck will not drive, just will rev up in each gear when you try to drive out. But one can change the gear position then.
Old 02-13-2018, 09:44 AM
Zjevans's Avatar
Thumbs up
Cheers mate,
If it is the slave cylinder or clutch master would i have to replace them or is there another way to fix them
and im australian
Old 02-13-2018, 09:56 AM
Zjevans's Avatar
And how can i tell whether it clutch master or slave cylinder
Old 02-13-2018, 12:58 PM
Cusser's Avatar
This is not so easy unless you see obvious leaks in one or the other. A clutch master cylinder can also leak under the firewall, under the dash.
I should mention that there are two small flexible lines in the system too, so make sure those are not cracked or leaking (I have replaced both on my own B2200). On my B2200, I generally replace BOTH at the time of a failure, and recommend biting the bullet and getting these from the dealer, or getting these with lifetime warranties (if available in your country) !!! And bleed out all the old fluid and replace with new.
Old 02-13-2018, 06:24 PM
Zjevans's Avatar
No worries and thank you
very helpful
Old 02-19-2018, 05:29 AM
Zjevans's Avatar
Hey Cusser just curious mate
if I replace both slave cylinder and clutch master and nothing changes does that mean it's the pressure plate
Old 02-21-2018, 09:00 AM
Cusser's Avatar
Go back and re-read Post #2. Check that release arm movement.
ll2009
11-30-2011 03:38 PM
danz09
02-15-2009 12:47 PM
penpen
12-13-2007 04:26 PM
90Rx7
01-02-2006 11:01 PM
bluemx693
09-13-2005 09:15 PM
Quick Reply: Clutch problem plz help
