b3000 info needed
b3000 info needed
hello fellas, ive got a 99 b3000 i just bought. i want to know if any body can tell me the types of brake fluid, auto. trans fluid , etc. to use. what about the motor oil that would be 5w 30 wouldnt it be? also what kind of gas mpg are you guys with 3000s and automatics getting ? is ther any trouble spots with these trucks?
thanks, mel
thanks, mel
RE: b3000 info needed
If its a 4x4 make sure to use it every now and then, even if its just to pull out of your driveway, they are designed to be used and even on a new car may stop working properly if they are not.
Make sure you keep up with fluid and filter changing on the tranny otherwise you will probably be certain to have premature problems with it but that is the same with any automatic.
Havn't heard anything else bad about them yet
