-   Mazda MX-3 and Mazda MX-6 (https://www.mazdaforum.com/forum/mazda-mx-3-mazda-mx-6-25/)
-   -   Shifts hard fromfirst to second? (https://www.mazdaforum.com/forum/mazda-mx-3-mazda-mx-6-25/shifts-hard-fromfirst-second-31983/)
tomeegun222 Jul 17, 2013 06:40 PM
okay so taking off it kinda does this back and forth motion and shifts hard from 1st to second gear and its not so bad from there but this is making me think its a motor mount but which one? what do you guys think?
tanprotege Jul 18, 2013 09:36 AM
Put it in neutral and pull the e-brake, add wheel chocks if the brakes don't work well. open the hood and grab the engine, rock it back and forth to see where you get the most flex. Inspect that corner with vigilence.
I almost suggested to put it on jack stands and have a friend rock it while you look at the mounts from below. But then I thought a car falling on your face might leave a permanent mark.....
tomeegun222 Jul 18, 2013 10:58 AM
haha ya just a little, i still need to do that but i work alot so maybe this afternoon ill figure out which one it is and so i can order it
tomeegun222 Jul 23, 2013 11:11 AM
okay so my car has FOUR motor mounts and i was confused because they all looked fine not cracked but didnt know about the 4th one under the battery box its pretty much ****ed so i ordered a new one AND a coolant temp sensor was one of the check engine codes so we will see what these two things do if everything is goodnext thing on my list is AC
tanprotege Jul 24, 2013 01:06 PM
Alrighty!
A/C is for the professionals. I've tried to get the A/C on the protege going. It is not reliable and I bypassed it with a shorter belt.
It did not work when i bought it. I filled it with refrigerant and ad it worked then for awhile. I found a small leak that is not easily fixed. Then the A/C clutch gave up. i replaced it with one from the junk yard , now the ocmpressor makes noises......
Ask a pro what it would take to get it done right.
tomeegun222 Jul 26, 2013 03:27 AM
Well It worked fine before it was parked ours been sitting a long time I have A feeling a charge will do the trick or at least I hope. AZ is the worst state to not have a/c in
tomeegun222 Jul 30, 2013 03:35 PM
1 Attachment(s)
Attachment 4386
This Is The Old Motor Mount!
tomeegun222 Jul 30, 2013 03:40 PM
1 Attachment(s)
Attachment 4385
This is the new one!!!
But it still shifts hard from 1st to 2nd any ideas anybody?
tanprotege Jul 30, 2013 05:33 PM
Sticky valve maybe?
I wonder if it is shifting hard when you play feather foot. Try accelerating real slow.
