Mx6 throttle body issue
Old Mar 5, 2015 | 06:22 PM
jmgrignon's Avatar
Default Mx6 throttle body issue
hi everyone, i have a 1993 mx6 4cyl 2.0l standard transmission. The car has 200000km and was only winter driven 4 years. Engine is still solid and does not burn oil.
My throttle body is finished. Stnadard giveaway is that idling is all over the place. My main question is that will a defective throttle body also affect engine temperature and cabin heating? Does the unit regulate those things too? any help would be appreciated.
Thank you
Old Mar 5, 2015 | 09:46 PM
hixx's Avatar
The throttlebody has coolant running through it. It is not uncommon for them to clog up and restrict flow. As far as the system hydrolocking if it is plugged, hmm, It is possible but unlikely. It would be worth checking it though. More likely the symptom would be a high/eratic idle.
Old Mar 6, 2015 | 07:55 AM
jmgrignon's Avatar
Default throttle body
i had no idea coolant ran through there. that explains a lot of things!! i have the replacement part and will ensure to install it properly. Thank you for your help, much much appreciated!!
fbmderek
Nov 17, 2014 08:17 PM
the_gray_mazda6
Nov 29, 2005 11:09 PM
rocket323
Nov 1, 2005 11:03 PM
rocket 323
Oct 29, 2005 04:52 PM
MaximusPrime
Jul 7, 2005 07:14 PM
