mazda mx3 error code
Old Mar 12, 2013 | 11:52 PM
jm12's Avatar
Default mazda mx3 error code
I have a mazda 1995 mx3 6 cylinder automatic trans.. does anyone know this error code??.. mx3 error code?..... - YouTube
Old Mar 13, 2013 | 09:11 AM
tanprotege's Avatar
To read the morse code: long =10, short =1. 1 long +5 short = 15
Look here for more:
link in post 2:https://www.mazdaforum.com/forum/maz...e-codes-31160/
and here:
Obd-I (Obd1) Code Reading Or Scanning - 1993-2002 (2L) I4 - Mazda626 Forums
Old Mar 14, 2013 | 05:15 PM
jm12's Avatar
hi tanprotege thanks for the information i really a appreciate!.. i checked the code from the video and from what i seeing its a long 1 and short 6 its that a code 15 or 16? and after that it followed by the short 5.. can you please check the video again.. thanks
BTW i found this MX3-Atlanta.com :: View topic - Check Engine Light Procedure and Codes (CEL)
Old Mar 15, 2013 | 09:30 AM
tanprotege's Avatar
You are right, jm12.
And here are the codes as used in the Ford Probe GT:
Interpreting the Codes:
There are quite a few codes. The following table shows the codes for the 1994 Probe GT (and a couple for the 1993) and what they mean:
Code
Circuit Diagnosed
Memorized?
'NE2' crankshaft position sensor
Yes
'G' camshaft position sensor
Yes
'NE1' camshaft/crankshaft position sensor
Yes
Knock sensor
Yes
Volume Air Flow sensor (VAF)
Yes
Coolant temperature sensor (CTS)
Yes
Intake air temperature sensor (IAT)
Yes
Throttle position sensor (TPS)
Yes
Barometric pressure sensor
Yes
LHO2S inactivation error
Yes
Exhaust gas recirculation (EGR) system
Yes
LHO2S inversion error
Yes
RHO2S inactivation error
Yes
RHO2S inversion error
Yes
Fuel pressure regulator control solenoid
Yes
Canister purge solenoid
No
EGR vacuum solenoid
No
EGR vent solenoid
No
Idle air control (IAC) solenoid
No
VRIS #1 solenoid
No
VRIS #2 solenoid
No
LFAN relay (1993 only)
No
ECTF sensor (1993 only)
Yes
So focus on the EGR. Pull out the EGR valve out and clean it and check it for operation. Clean the passages and orifices. EricTheCarGuy has a good video on Youtube.
Once you have that working the knock sensor will likely be fine as well.
Bookmark this:1993-1995 Engine Controller Malfunction Codes
Old Mar 15, 2013 | 08:37 PM
jm12's Avatar
thanks a lot tanprotege! your really a big help.. i hope it fix the knock sensor too when i clean the egr valve.. btw do i need to reset the check engine light or it automatic reset it..
Old Mar 16, 2013 | 03:33 PM
tanprotege's Avatar
I suggest you reset the CEL by disconnecting the battery negative and stepping on the brake for 5 seconds or so. The brake light circuit will drain any residual voltage from the computer and thus erase the memory.
If the CEL comes on again you know there is still work to do.
I wish I could take yourMX 3 for a spin!
Old Aug 22, 2013 | 06:34 PM
tomeegun222's Avatar
mines pulling a 28 and 69 i think?
Old Aug 22, 2013 | 10:00 PM
tanprotege's Avatar
ECTF sensor stands for "Engine coolant temperature Fan" sensor.
Old Aug 23, 2013 | 01:56 AM
were is this part? i would like to replace and see if that cancels one code
Old Aug 23, 2013 | 02:03 AM
heres my check engine light what numbers are you seeing???
