Help Please.....
Old Mar 15, 2006 | 05:44 PM
Cpumage's Avatar
Default Help Please.....
I have a 98 mx-6 non turbo. The car would just die when ideling or going down the road. After alot of trial and error I found out the problem was my control module in the distributor. So I put a new one in and it started right up. But now runs real bad like its out of time. But I timed it and thats not it. Please give me any ideas you have.
Old Mar 15, 2006 | 06:45 PM
u.dick's Avatar
Default RE: Help Please.....
check the basics... compression, timing, etc. does it idles rough with or without the a/c on? Need to figure the exact symptoms before moving on.
Old Mar 15, 2006 | 06:49 PM
Cpumage's Avatar
It idles rough without the ac on. I checked the timing and thats not it. Dont know much about compression. It starts right up but runs way to rough to drive.
Old Mar 15, 2006 | 07:01 PM
u.dick's Avatar
ok, does it idle rough or does it ride rough? 2 different issues altogether.
Old Mar 15, 2006 | 07:06 PM
u.dick's Avatar
It can be a number of things. Not knowing the condition of the car, I would go in process of elimination.
1. check plugs, wires, fuel filter, PCV valve, etc.
2. No codes from the PCM?
3. Bad vacum hose can cause this (rough idle, lack of power, etc)
Old Mar 15, 2006 | 10:25 PM
babyhuey's Avatar
Did you double check the routing of the spark plug wires? Firing order is 1-3-4-2.
Old Mar 16, 2006 | 01:59 PM
u.dick's Avatar
I doubt the car would even run with wires on the wrong plugs.....
Old Mar 16, 2006 | 04:03 PM
Cpumage's Avatar
These are the things I have replaced. Plugs, wires, fuel filter, fuel pump, ign control module, distributor cap, rotor, vacum hose, pcv valve, I have timed it, I checked the fuses. As far as the fireing order is that 1 3 4 2 from the left? Thanks for all the help.
Old Mar 16, 2006 | 04:21 PM
Cpumage's Avatar
My book says the firing order is 1 2 3 4 from the left for a 89 mazda mx-6 non turbo
Old Mar 16, 2006 | 06:01 PM
u.dick's Avatar
1-3-4-2 basic for all 4 cyl engines. Starts at the front of the engine.
