engine doesn't start
Old Oct 23, 2014 | 12:07 AM
riccardop's Avatar
Default engine doesn't start
I got an '92 MX3 1.8 V6
I have this problem. when i turn the key some lights on the panel light up including the 'engine light'. and that's normal and then the engine starts.
well sometimes this 'engine light' doesn't light up on the first click of the key, and so the engine doesn't start.
Anyone has an idea??
Old Oct 23, 2014 | 08:18 AM
hixx's Avatar
Need more info really. Does the starter turn the engine over? If not it is probably the ignition switch. You can buy just the electrical portion of it.
Old Oct 24, 2014 | 08:52 AM
riccardop's Avatar
yes the engine turns over but it stars only if the engine light was previously on
Old Oct 24, 2014 | 10:44 AM
hixx's Avatar
Under the hood is a small black box, that is the diagnostic connector. Open it up and put a jumper wire between grd and ten. Turn the key on and count the check engine light flash's if it will even flash. Might be the bulb is bad too.
mfletterman
Jun 18, 2012 08:02 AM
doodle1960
Aug 27, 2008 08:14 AM
dfp48@hotmail.com
Aug 24, 2008 09:22 PM
Trivek
Oct 26, 2005 03:57 PM
