ABS computer reset
Old Mar 13, 2021 | 03:35 AM
Tymen Brom's Avatar
Default ABS computer reset
Hi folks,
I am a new member I am rebuilding a Eunos 30X- Mazda Mx3 with my son for his first car and we have run into a problem with the abs
We have the abs warning light on and can't get the computer into diagnostic mode. We have tried connecting the TBS to GND in the diagnostic connector and get nothing.
I have also gone through the service manual and done the wiring checks and can't find a problem. Wheel speed sensors are behaving as expected, same for pump and solenoids and abs fail safe relay
I want to get it computer into diagnostic mode so i have a hint of where to look for the problem and then reset the computer.
Does anyone have any suggestions?
Old Jan 7, 2022 | 02:30 AM
Alkol's Avatar
I have a 2003 Chevy Astro Van which had the ABS Module and pump replaced less than three years ago. I haven’t been driving it much the last week but lots of rain here visiting my parents.
Tutuapp 9Apps Showbox
Old Jan 11, 2022 | 06:37 PM
Rampi's Avatar
Originally Posted by Tymen Brom
Hi folks,
I also have problem with abs. After mechanic changed sensor for other one (computer showed that he was faulty) but not original mx3. For one that comes from 323. Since then abs light is constantly. Today i did jumper from TBS to GND and i had just normal view of dashboard. Abs light lightin constantly. I did same procedure but with diode on diagn port but there is also same effect. Constans light.
Old Jan 15, 2022 | 07:14 AM
Rampi's Avatar
Ive found the solution to your and mine problem. If u want to check your faulty codes you have to jumper TBS-GND and use diode witch resitor (i used red witch 470Ohm) and jumper B+ with FBS.
skyrider
Dec 29, 2022 05:47 AM
loriandan
Jun 25, 2011 06:23 AM
mzbenami
Oct 27, 2009 04:14 AM
billnmimi
Mar 27, 2008 06:19 AM
Pump Man
Oct 30, 2006 03:48 PM
