1.8 v6 convert to 2.5 v6
Old Apr 25, 2006 | 10:34 AM
kukujiao's Avatar
Default 1.8 v6 convert to 2.5 v6
hi everyone,
i have a 1994 mazda mx-3 1.8 v6, recently i saw one engine from the e-bay, it was 1995 mazda mx-6 2.5 v6 engine, does anyone know that how much it cost for the convertion fees and does the mazda mx-6 engine fit to mx-3 gearbox? thanks a lot...
Old Apr 25, 2006 | 12:10 PM
sstlaure's Avatar
Default RE: 1.8 v6 convert to 2.5 v6
Are you sure you have a 1.8L V6 (and not a 1.8L I4)
Old Apr 25, 2006 | 03:35 PM
babyhuey's Avatar
Mazda did in fact have a small 1.8l V6 in the MX-3 for the few short years they were in production called the K8 engine. What a blast of a rocket they were to drive with the 5-speed manual trans. A shame they did not last longer than 4 years on the Mazda lineup.
Do not know what kind of cost you would be looking at to convert to the 2.5l KL engine but will probably depend most on how good of a conversion is done. They should however mate up to the trans ok as both V6 models shared the same G25M-R manual transmissions.
Old Apr 25, 2006 | 03:46 PM
sstlaure's Avatar
That's killer. Those would be like motorcycle sized pistons/connecting rods. I bet it could sound mean as hell with a build-up and revved up quick.
Old Apr 25, 2006 | 04:54 PM
babyhuey's Avatar
Yea, the pistons are just under three inches in diameter. Really tiny guys at least in comparison to the ones in my .040 over dodge 440. There is a similar conversion car running around here but was a really crappy install and it never runs right. They should have left well enough alone in that case.
Old Apr 26, 2006 | 08:30 PM
kukujiao's Avatar
thanks for the reply...
Old May 2, 2006 | 02:58 AM
ajanssen's Avatar
I actually did this. I'm just in the tuning stages right now. I had a japanese KLZE imported for about $14-1600 I can't quite remember right now. Replaced the timing belt and waterpump for about $200 before the install, just so much easier with the engine on a bench. It moves like a scared rabbit now, just idles like a bag of crap. I'm thinking it's the TPS, anyone have any other ideas?
Old Sep 15, 2006 | 12:44 PM
dohcb6mx3rs's Avatar
make sure u get at least a u-spec ecu out of a probe or mx6 best would bethe j spec ecu and also make sure u have the vaf from the bigger 6 to that could be ur idle problem
Old Mar 8, 2008 | 10:09 AM
dogstar's Avatar
the 2.5 goes staight in all you have to do is change one engine mount and extend a few sensor wires its a weekends work,we do alot of these in the u.k check out <mx3.com> for detailed info look up engine swap.
romedog99
Aug 14, 2009 03:05 PM
blueblazes
Apr 26, 2007 02:47 PM
kamikazzz
Nov 8, 2006 05:00 AM
Maurice
Aug 15, 2004 01:39 AM
