How do I reset power window / jam safe function?
Old Sep 8, 2022 | 06:31 AM
RajKJoshi's Avatar
Default How do I reset power window / jam safe function?
Driver side window goes up ok but after touching top it bonces back half way. Seems jam safe function getting activated unnecessarily.
Can someone help please to reset/reprogram window switch/logic for Mazda MPV 2002 v6 model?
Old Sep 8, 2022 | 07:00 PM
robinsone's Avatar
That sounds like a bad window regulator or one going out, not a jam safe function
Old Sep 8, 2022 | 07:51 PM
RajKJoshi's Avatar
Thank you for your reply,
Is it worth doing reset prior to spending money on replacement, which may also need reset procedure for first use.
Old Sep 11, 2022 | 08:21 AM
RajKJoshi's Avatar
Default Solved
Basically window motor logic was thinking window hight being higher than actual window, so after reaching top jam safe function was getting activated.
I fixed it HARD way !
Took the windown regulator assembly out and separated the motor and slided the bracket (where two bolts for glass gose in ), DOWN and reattached the motor, and put all back in.
So annoying that I couldn't find reset procedure from anyone. Mazda agencies were just looking to make money rather this reset procedure should have been the part of owner's manual to begin with.
kimberlysmoore
Oct 20, 2020 08:07 PM
Bigbaby
Aug 22, 2014 09:00 AM
divvie
Sep 12, 2011 07:58 PM
neevsmazda07
Jul 16, 2011 12:23 PM
punkascii
Aug 10, 2009 05:34 PM
