Grinding noise in reverse only - 97 MPV
We have a 97 MPV. Going forward there is no noise, everything sounds fine. When reversing there is a loud grinding noise that I thought was coming from the rearbrakes. I had the brakes done because they were due anyway, but itstill makes the noise. I discovered if I let the car roll backwards in nuetral it doesn't make the noise; so it can't be the brakes. I found something on google about the dust cover on the drive shaft was re-designed because they leaked water and could cause the inside bearing to rustand make noises.
Any ideas? Thanks.
Any ideas? Thanks.
bethany626
Apr 11, 2011 01:48 PM
dfp48@hotmail.com
Aug 24, 2008 09:22 PM
leftygolfguy
Nov 30, 2007 08:55 AM
