Camshaft PULLEYS
Old Jan 25, 2009 | 09:47 PM
fourwayz's Avatar
Default Camshaft PULLEYS
Here's a "doozie"! I currently own a '94 MPV that needs another engine. I just purchased a '97 with a severely shredded belt. The right camshaft "pulley"(by mazda's definition) was damaged on the 97. Are the pulleys interchangeable between the '94 and '97 engines?
Old Jan 26, 2009 | 03:59 PM
s0eebuch's Avatar
Default RE: Camshaft PULLEYS
I'd check the part numbers on partsamerica.com or autozone.com. Check the 1994 model, write down the part number, then check it again for the 1997 model and check that number against that which you wrote down.
if they match, you're good to go. I've also called the dealership to verify both P/Ns if it is a part that I do not want to goof on.....
good luck.
dzurot
Mar 5, 2011 05:29 PM
94davenport
Nov 10, 2005 09:08 PM
_Mike_
Sep 17, 2005 04:05 AM
westy
Sep 12, 2005 12:25 PM
snapring6r
Apr 25, 2005 07:42 PM
