2006 MPV - Turns over, sputters, then dies
As the title states, it'll turn over when jumped (don't know how good the battery is), and will sputter for a cycle or two, then dies. I pulled the fuel line, and when in the on position, it sprayed gas everywhere. Doesn't seem to be the pump or in-tank filter, unless it is only getting enough pressure for the first few cycles, then drops. I didn't let it continue spraying long enough to see if it kept the same fuel pressure.
Is this common?
Is this common?
