2006 MPV Timing Belt or Chain?
In the 2006 MPV maintenance schedule I do not see anything about when to have the timing belt changed.
Does the 2006 MPV have a timing chain that typically should not have to be changed within a specific maintenance schedule? |
RE: 2006 MPV Timing Belt or Chain?
All 2000 and later MPV's use a timing chain kh_design. At least in North American market.
Thank you for the prompt reply.
Typically should timing chains on the 2006 MPV not have to be changed within a specific maintenance schedule? Do timing chains on the 2006 MPV have a long life expectancy, how many miles should be expected with the typical timing chain on the 2006 MPV? |
I am hearing 250,000 miles is the typical life expectancy for the timing chain on the 2006 MPV.
That would be a fairly good guesstimation on longevity as I have not yet seen any failures but have also not seen any MPV's with chain engines having that many miles yet.:D
Just noticed this weekend that the timing chain can be seen when the engine oil fill cap is removed.
