2005 Mazda MPV 3.0 V6 Oxygen Sensor
Old May 30, 2011 | 10:40 AM
MPV_2005's Avatar
Default 2005 Mazda MPV 3.0 V6 Oxygen Sensor
Hi,
I own a 2005 Mazda MVP, my vehciles sevice engine light came on, since that i took the vehicle to auto zone to check the code and came up with bad 02 oxygen sensor, i need to know how to replace. is there more than one, if so which one should i replace. what is the difficulty on replacing, please advice, any information will really help. dont have much money to put in the shop.
thanks to all
Old May 21, 2012 | 11:53 PM
Deathwish657's Avatar
Which Oxygen sensor is it? There are like 3-4 different ones. If you know the Code they got that would actually give you a good spot to be looking since it would give you the location more when its looked up online.
My code i got is PO155 = Oxygen sensor 1 Bank 2
(Ofcourse i still never got it fixed.. Replaced it but something else still making it not work..)
Old May 22, 2012 | 07:34 AM
You won't get a response. That was 1 year ago. Damn thread sort.
Old May 23, 2012 | 03:31 AM
LOL. Yea.. I realized that after i posted :P
Old May 25, 2012 | 05:40 PM
steffanj's Avatar
Default Po155
Hi all I have a Mazda Tribute 2001 with the check engine light on. I have had it diagnosed as PO155 heater core circuit. Is this sensor easy to change as there is two upstream sensors. Also My fuel economy has gone through the roof is this to do with this sensor.
Steff
Old May 26, 2012 | 06:48 PM
Bank 2 is where cylinder #2 is at. (Cylinder #2 is in the front of engine, closest to radiator) Sensor 1 is the sensor before the catalic converter. In total, there are 4 sensors.
2 Upstreams, 2 Downstreams.
They are not hard to replace, just gotta get the o2 socket set to get them, since they are in a tight spot. Connection for bank 2 sensor 1 is near the cooling hoses, under waterpump area.
Old Jul 18, 2017 | 02:04 AM
thegolffather's Avatar
Wow great information, I wish it had pictures
Old Sep 13, 2017 | 10:11 PM
05MPV's Avatar
had both pre cat sensors replaced and now no more CEL and back to normal fuel mileage
Old Dec 14, 2019 | 03:51 PM
Soljhon's Avatar
How many o2 sensor are there on mazda mpv and where are the locations.thnks
Old Dec 18, 2023 | 11:08 PM
smspitler's Avatar
MPV 3.0 has 4 O2 sensors. Two upstream (prior to the converters) and 2 downstream (after the converters). Bank 1 is closest to the firewall and bank 2 is closest to the radiator.
Revy
Jan 9, 2012 09:41 PM
Deevan
Nov 9, 2010 07:37 PM
jasoneaton
Aug 13, 2010 02:59 PM
pvillalta
Jun 23, 2009 02:04 PM
Declan
Feb 27, 2008 08:47 PM
