2004 MPV - Front A/C Intermittent
Ok, we have a 2004 MPV with front and rear A/C.
Rear A/C is fine, always works, gets really cold. So we can rule out a compressor issue. On the Front A/C System, the fan does not start with the vehicle, sometimes it comes on after a little while onthe road. However, the longer we have this problem, the less likely it seems the A/C Fan will start. I saw one post here that said to check the Cabin Air Filter, but I can't find that in the Owner's Manual. Any other suggestions or ideas? Thanks! (Edited - orginally said 2002, but front of owner's manual says 2004) |
RE: 2004 MPV - Front A/C Intermittent
Sounds like the brushs in the fan motor are worn out. Turn it on and bang on it under the right side dash. If it comes on put a motor in it. If not you need to pull the connector to the motor and check for power to it and trace backwards. Relay,blower resistor, fan switch and related wiring.
