2002 MPV Sliding continuous beeping right door only
Old Jun 12, 2008 | 07:58 PM
Vaniam's Avatar
Default 2002 MPV Sliding continuous beeping right door only
Found trouble codes 19, 21 and 42 for right sliding door.
When pressing any door open switch for the right door, door will not open and the door alarm will sound continuously until power switch is turned off. If door is open pressing any closed switch will not shut the door and the door alarm will beep continuously until power is turned off.
The left door operates normally.
Pulled the negative terminal from the battery for 30 minutes.
I have not checked the trouble codes on the left door.
This problem started when I was pressing the front closed button while another person was pressing the rear button.
All components appear clean, the ground next to the control box on the right side is clean and rust free.
Any ideas?
Old Oct 11, 2008 | 07:28 PM
oldzoomer's Avatar
Default RE: 2002 MPV Sliding continuous beeping right door only
Just read your post. I have the same problem with my 02 MPV, same door. No solution yet.
Did you resolve your problem, and if so how?
Old Oct 11, 2008 | 09:09 PM
Vaniam's Avatar
Continuous beeping stopped when I turned the power switch to the door off then on.
Trying to open the door again would produce the beeping again.
My solution was embarrassingly simple, blown fuse. Doh!!
Good luck.
CharlyFh
Feb 2, 2014 08:53 AM
Xato
Mar 6, 2010 08:41 AM
dietz
Mar 14, 2008 12:03 AM
mafv112
Mar 10, 2008 04:33 PM
nellympv
Jan 16, 2006 04:23 PM
