smoke from engine, detailed description
i have a 95 millenia s. there is a light white smoke coming from the back left area (when lookin at from front) of engine. the smoke is on and off. there will be no smoke for a while then smoke for a few minutes. the smoke smells like burning rubber most of the time but every so often smells like burning oil. not sure what to check for i've snooped around and found nothing burning or any oil leaks. any ideas from anybody on what to check?
In general......out the exhaust pipe
White smoke: Coolant (head gaskets?, somehow liquid is getting into the combustion chamber)
Blue smoke: Oil (valve seals, head gaskets, again, oil is getting into the combustion chamber)
Black smoke: Gasoline (running rich)
Now if you're looking under the hood, maybe have someone in the car to rev it up a little to get the drip going. make sure there aren't any hoses touching the exhaust (burning rubber). If the smoke is white and not bluish, then it's most likely coolant.
If you find an oil leak. Trans fluid is red, regular oil is brownish...
FenderHead
Mar 8, 2010 07:09 PM
The_Editor
Apr 26, 2009 10:14 AM
Presidential_Detail
Detailing
Dec 14, 2008 01:19 AM
Brn2Tz
Oct 13, 2008 12:56 PM
