Slipping trans
(I'll try to get the codes tomorrow - the reader won't connect)
Now, I'll start by stating that this has been going on for almost two years; Trans slips into all gears with HOLD OFF but, will shift just peachy when HOLD ON. Basically, I've been drivingher like a manual. Shifting with the stick however, this is getting to be a pain in the ass! Especially, when I leave her in third for 60 miles in the morning. (forget to run overdrive and suck down more precious gas) Any suggestions before I drop the powertrain and fit 'er with a rebuilt transmission? |
RE: Slipping trans
Still no codes ... I'm thinking something is wrong with the interface. (unable to negotiate error)
RE: Slipping trans
Check the solenoid pack. Non-shifting automatic cars usually have a problem with the solenoid, selectors (inside the bell-housing), or for front-wheel drive cars, it might be the speed sensor which is usually located on the wheel. Speed sensors indicate when a car should shift to a certain gear. It seems that you have a speed sensor problem. Check your local Napa or car dealer for this part. Installation should be easy. I hope this helps.
RE: Slipping trans
Thanks CHR.
I'm assuming that the solenoid pack investigation will require me to remove the transaxle? (I've had plans on removing it soon) I still can't get the dam codes out. I ended up erasing them over the weekend to see it they/it would reapear. (disconnected the battery) And, sure enough ... it's back. As soon as I get the code (somehow) it should point me in some direction. |
| All times are GMT -5. The time now is 07:44 AM. |
