Mazda Millena 95 Intermittent stalling issues
Old Jun 17, 2009 | 07:24 PM
trunner_2000's Avatar
Did you every try the main relay? Did it fix the problem
Old Jun 17, 2009 | 07:27 PM
Did you ever try the relay? What was the result?
Old Apr 24, 2012 | 07:53 PM
anthonycolicino's Avatar
I have the same issues on my 2002 2.5L, but after replacing the main relay fuse it is still stalling and stammering. Does unplugging the EGR sensor still work as a sufficient fix? Also, what ended up being the long-term repair for this issue?
Old Jun 8, 2017 | 05:58 PM
bklynras's Avatar
Did anyone find out the fix for this problem? I have the same issue... 500rpm intermittent drop while driving. I changed all vacuum hoses, rotor and cap, wires, plugs, cleaned EGR, cleaned IAC, cleaned ground points (under air box, next to thermostat, in fuse box). going to disconnect egr booster now
Joe428
Apr 26, 2022 02:09 PM
sborders
Jan 16, 2013 05:16 PM
mazdajim
Aug 13, 2012 01:56 PM
iamcollin
Apr 16, 2012 05:18 PM
megaquark
Oct 15, 2007 06:14 PM
