HELP!!! TIRE QUESTION!!!
I have '99 Millenia with the stock 16inch wheels. I know the correct tire size is 215/55/16, but i'm wondering what other sizes will fit the car. I would like a little bit bigger tire for smoother ride, but how big can i go with out rubbing?
Try Continental Conti's. I use them and the ride is great. Remember, you don't have a performance auto but rather what is classified as a : near luxury auto. I suggest you keep your 16 inch wheels but check into a different tyre size.
What I am suggesting is that you stick to the 'original' size but go to a different tyre brand. In the alternative get onto the tirerack.com web site and there you will find different sizes that you can install on your 16 inch wheels.
captain
captain
the taller than stock tires might throw your vehicle speed a little off, let said your travelling on the highway doing 65 on the speedometer, but in reallity your car might be faster than that, i recommend that you go to the tires shop, they can give you a good suggestion. normally, if you go taller, then the width will be narrower
215/55/16
205/60/16
you will get a smoother ride, but suffer a bit in the handling
215/55/16
205/60/16
