Help babyhuey
Babyhuey, I read alot of your answers and you really seem to know your stuff. I would appreacate your help with this one.
I have a 95 Millenia S with a MC engine that will run on 5 cly from time to time. We replaced the #2 injector last week and it ran great for a short time. Now it is acting up again. The CE is on but when I jump Grd and 10 no codes are present. Could it be a bad coil pack on #2. Help |
RE: Help babyhuey
We haven't seen babyhuey in about 3 months...not sure what happened.
Have you tried using an actual code reader? They don't cost anything to borrow and they even translate the code into what is wrong. |
RE: Help babyhuey
most of the 95 is still obd1.
since #2 coil is right there in front, just swap it, and see if the miss follows it. it only takes about 30 min to pull the coils on the front bank |
RE: Help babyhuey
Thanks , I will try swapping the coil. Does anyone know if a defective coil can cause a new injector to fail ??
RE: Help babyhuey
It shouldn't. A bad coil should just prevent spark at that cylinder.
