Coolent leak 02 Millenia S
-It started with the usual vacuum leak which I found and repaired.
-While I was at it Idecided toservice the air cooler since I had it off anyway.
-When I re-installed everything I didn't secure one of the coolant lineson the EGR valve.
-It overheated.....bad!
-It runs fine but now I have a leak behind the timing belt cover.
-I removed the water pump but didn't see any visible damage.
-The water pump has only 10K miles since I replaced the timing belt.
-I re-installed everythingwith some new sealant on the WP.
-It still leaks.....
-HELP!!!!!
-HELP!!!!!
