Changing font turning signal light bulb
Old Aug 13, 2010 | 11:44 PM
MazdaSilva's Avatar
Default Changing font turning signal light bulb
Is there a diagram on how to change the front turn signal light bulb?
Also where can I find the clear plastic cover of where the lights are located. As time has passed the plastic cover in my head lamps have gotten cloudy.
Old Aug 14, 2010 | 11:31 AM
t2t's Avatar
t2t
What year is your Milly? Is it the side marker light that you're trying to get to? I have a 2002, and to get to that light, you have to go through the fender well - which involves taking out 1/2 dozen screws so the plastic well can be pulled back to reach the bulb.
As far as cloudy head lamp lenses go, it will probably be big $$ to find the proper replacements. Instead, look into one of the kits to refinish them so they're nice and clear again. Maguiers has a special polish and a buffer for your drill to polish the lens back to where it should be. I've also used a kit from Wal-Mart that costs about $20 and involves sanding the lens with a high grit sandpaper to sand the lens and then some acrylic liquids to put a nice polish back on the surface.
These methods are about the easiest and cheapest ways to restore the headlights. Replacing them with new ones will also require you to re-align the new ones - a bit of work, etc.
Old Aug 14, 2010 | 12:49 PM
MazdaSilva's Avatar
Mine is a 2002 2.5L. Yes that's correct, the light I'm talking about it's the side marker light. So I have to take the fender off to get to that light?
Thanks for the response!
Old Aug 14, 2010 | 02:50 PM
t2t's Avatar
t2t
No, you don't have to take the fender off - just the inside of the fender - the fender well, which is the plastic/rubber part that is accessible from your wheel area. You may not have to take the whole piece off - just enough of the screws/bolts so that you can reach your hand through an area to access the light socket to replace the bulb. On my 2002, the light bulb can't be accessed from the engine compartment. Though, the rest of the bulbs on the front can be.
Old Aug 14, 2010 | 11:35 PM
t2t's Avatar
t2t
Here's a link on how to make your headlight lenses clear again:
http://www.wikihow.com/Repair-Oxidiz...dlight-Cleaner
MoonFlag
May 5, 2011 01:30 PM
Lodebar
Nov 8, 2009 01:39 AM
jimfrostis
Mar 19, 2008 06:01 AM
Siber Express
Nov 15, 2007 07:11 PM
laredotexas
Aug 7, 2006 12:13 PM
