98 Millenia S wont shift/bad SC no codes.
I have a major problem with my millenia. The supercharger was bad when i got the car, sounded like a rod knock. To be positive i cut the belt.. I could not get the belt off and it was shot anyway. The car will run fine, when i put it up on stands and try to get the car to shift it will not do so. When i try to drive it it will not shift TC off or on makes no difference. The car has a transmission leak i think its from a CV seal. I just want to sort this shifting issue out before i do any work at all, if the transmission is bad i'am SOL.
I try to pull codes with the normal obd2 connector, and it fails to connect i tryed a snap-on and mac reader. There is another plug but i don't have a mazda connector, and i assume that is what this second connection under the dash is for? So will a disconnected/bad supercharger make my car not shift at all? Even up on jack stands. The speed-o works so it cant be the speed sensor. |
Originally Posted by sohcnick
(Post 130620)
I pulled the transmission pan and, found a lot of metal scraps.. The transmission is done for so this car is going to be parted out. PM if you need parts ill send pictures, the car still runs i have not ripped anything out yet. Car has 131k.
