95 millenia dash clock/a/c LED
My 95 millenia suddenly quit displaying the A/Cand heatertempand clock. I checked fuses that apply and found none bad. The A/C and heater still work fine. I just have no read out. Is there a bulb behind the display? If so, how do I replace it? Does the plastic lens in front of the display pop out? All the rest of the dash lights and displays work fine. Can anyone help????
RE: 95 millenia dash clock/a/c LED
ORIGINAL: wilburn My 95 millenia suddenly quit displaying the A/Cand heatertempand clock. I checked fuses that apply and found none bad. The A/C and heater still work fine. I just have no read out. Is there a bulb behind the display? If so, how do I replace it? Does the plastic lens in front of the display pop out? All the rest of the dash lights and displays work fine. Can anyone help???? |
I just brought a AC Display online and im having trouble replacing it with the old one... Could anyone tell me Where are the screws located and how many are they? I tryed today but it seems like somethinng is still holding the dash in... maybe im missing some screws
on each side of the steering wheel, you will see a rectangular cover. underneath is a screw. take these off, then the entire assembly pops off. i open the glovebox, and gently pry from there. the assembly comes off just enough to disconnect the harness's.
Is there a screw under the dim light control? Im having trouble removing that cover...
Anyone know?.....
ORIGINAL: mrmoneyman Anyone know?..... |
| All times are GMT -5. The time now is 03:23 AM. |
