2002 Millenia Check Engine light
Old Mar 17, 2010 | 11:49 AM
ghat's Avatar
Default 2002 Millenia Check Engine light
I just bought a 2002 Mazda Millenia with 41,000 miles and it's a beautiful looking and running car. I ran it low on fuel and this morning the check engine light came on. I checked the gas cap and it seemed to be seated and would like to know if I can reset the check engine light or will it go off automatically when a problem is fixed. Will disconnecting the battery reset the check engine light?
Old Mar 23, 2010 | 09:15 PM
Megalomegalodon's Avatar
Disconnecting the battery should clear the CEL. You should really invest in a code scanner that can clear as well as read codes.
Old Mar 24, 2010 | 06:02 AM
ghat's Avatar
Default check engine light is intermittent
Thanks for the response. This problem is very strange. The light comes on in the mornings when I start my car but in the afternoon it doesn't. I live in South Florida and at night my car is parked in a covered parking lot less than 50 yard from the Atlantic Ocean. I did have it connected to a code reader at a local auto parts store while the light was on and it indicated that my knock sensor is bad or that it has a loose connection. Can moisture in the air cause this problem?
The car runs great and has no loss of power.
ryanslu
Apr 15, 2012 06:29 PM
jbstrunk
Jun 14, 2011 09:34 AM
wirelesscop
Oct 17, 2006 03:15 PM
msparker505
May 19, 2005 10:20 AM
msparker505
May 10, 2005 02:21 AM
