Water in engine compartment Miata 2000
Old Apr 7, 2007 | 05:15 PM
tbbilli's Avatar
Default Water in engine compartment Miata 2000
I received some water in the engine compartment and afterwards,
the car started to running sluggish (missing) in first adn reverse
gears. Is this something I should be alarmed about or will it
work itself out after the engine completely dries out? Thanks!
Can I try anything to help first and reverese gears...
Old Apr 7, 2007 | 11:22 PM
babyhuey's Avatar
Default RE: Water in engine compartment Miata 2000
Sounds like you probably sucked some water into your intake air system. Regardless of if the intake is cold air induction type or orignial equipment, I would start by checking the filter element for being soaked and also the air passage before the air filter for water accumulation. Does it look like water may have splashed way up into the engine area. If so then also try removing the spark plug wires and make sure that water is not down inside the spark plug wells in the cylinder head.
babyhuey's Avatar
Old Apr 10, 2007 | 01:31 AM
wsoape281's Avatar
if there is water in the cylinders, i would just put in a new set of spark plugs and throw in a fuel treatment, preferrably something with ethanol since ethanol dissolves water.
kct
Feb 9, 2010 03:53 PM
thc888
Jan 1, 2010 03:34 PM
8thborn
Jun 25, 2006 01:31 PM
ripcbx
Dec 24, 2005 04:29 AM
the_gray_mazda6
Nov 19, 2005 12:37 PM
