Parking Brake???
Old Sep 14, 2005 | 02:22 PM
osumx5's Avatar
Default Parking Brake???
On my '90, the parking brake line wont release even though the handle will release. Anybody know how to fix the problem?
Old Sep 14, 2005 | 04:24 PM
gtxtreme's Avatar
Default RE: Parking Brake???
Several possible problems to diagnose. Either one or both your park brake cables are corroded. Either one or both of your rear caliper operating levers are corroded. You'll have to jack up the back end & pull the wheels. With a pair of channellocks try moving
the operating lever ( cable attached) if they move, have someone use the park brake to find which cables not moving.
Old Sep 14, 2005 | 11:05 PM
babyhuey's Avatar
Are both rear wheels locked by brake or only 1 side?
Old Sep 15, 2005 | 05:57 AM
bluebomberx's Avatar
How long was it engaged? Sounds like it could've rusted in place. I'm not sure what to do about it off the top of my head. The answer might be here though --> http://www.miata.net/garage/ebrake/index.html
Old Sep 15, 2005 | 05:58 AM
Skimmed the article. The answer is at the bottom under Failure Modes.
Old Sep 16, 2005 | 02:54 PM
osumx5's Avatar
First off, it only has 18,000 miles, second, i have been daily driving it since i bought it with 15,000 in May. I put 17's on it, so the brakes are exposed. I use the parking brake on a daily basis. Both rear wheels are locked up. It happened a week ago, but released. I was driving in a rain storm the other night, and the next morning the brake wouldn't release.
Old Sep 16, 2005 | 07:06 PM
ORIGINAL: osumx5
Well it is still 15 or 16 years old even if it only has 18000 miles. I wouldn't be suprised if it's rusted up. The brakes are exposed to the elements regardless of what rims you have on the car.
Old Sep 18, 2005 | 01:52 AM
babyhuey's Avatar
Read the article briefly. Is unlikely that the calipers were the problem if indeed both were locked up at the same time and released the same. Would suspect one of two things. The main cable that goes from your lever inside to the cable splitter under the vehicle or the pads became rusted to the rotors and would not release the rotor. How sure are you that both wheels were locked up and not just one side?
Old Sep 20, 2005 | 05:58 PM
osumx5's Avatar
Thanks for everyone's input, it turned out that it just needed some lube, kinda retarded that i didn't notice it, but thanks again for the suggestions.
doctor_joe87
Feb 15, 2009 08:59 PM
dbockcac
May 21, 2007 12:05 PM
bdubbs84
Dec 25, 2006 12:49 PM
STEVE MASTERS
Nov 4, 2006 09:12 PM
Boomer27
Feb 13, 2006 12:40 PM
