HEADLIGHT UPGRADE- 2006 Mazda Miata Grand Tour
I recently had to replace my low beam headlight for about the 6th time. decided to try LED bulbs. Low beams worked great but were bright white, High beams were yellow, so I thought lets replace the high beam as well. I was happy with the looks but the High beam indicator on the dash stayed on even when they were off. I also noted that the high beam bulb had just a tickle of light being emitted from the bulb while running the low beams & fog lights. I was told I needed to add the inline LED Headlight Canbus. I installed the "Xprite LED Headlight Canbus" system & turned them on, POP no more fog lights at all & no longer have any Bright lights either, not even the dash indicator. I have checked fuses & can not find a blown fuse? When using flash to pass just the low beams iluminate.
HELP!
HELP!
