1999 Mazda miata rough running
Old Aug 14, 2006 | 11:34 PM
amurphy's Avatar
Default 1999 Mazda miata rough running
I have an interrmittant problem with my 99 Miata (38000miles). It will start and run fine, and depending on it's mood, when I have driven somewhere and killed the engine, it will be very hard to start, and when it does start, it sounds like it is running on only 2 or 3 cyls, strong smell of gas at the exhaust. You can then hit the road, very rough running, and at about 40mph, it is like you flip a switch and every thing is ok for a week or two, then it does it again. Sometimes the check engine light will come on but I do not have a reader yet. I cleared the check engine by disconnecting the battery. Any suggestions??
Old Aug 18, 2006 | 12:01 AM
Joe10ae's Avatar
Default RE: 1999 Mazda miata rough running
sounds like coil pack. Could be some other stuff, but the coils on these things SUCK. Mine went at about 38k too. Finishlineperformance.com is the place to get the new ones $222. Get NGK blue spark plug wires while your at it (assuming you don't have good wires already)
Old Sep 3, 2006 | 10:04 PM
amurphy's Avatar
Changed out the coil pak, have not had any more problems yet. Thanks for the help.
Old Mar 19, 2007 | 12:18 PM
azncharm01's Avatar
Hi! New to this forum. I have the same problem (00 Miata LS auto). My mechanic changed the spark plugs, wires AND fuel pump but problem is back in 2 weeks. Im wondering if changing the coil pack solved your car's problem (long term).
Old Mar 27, 2007 | 09:30 PM
CHR's Avatar
CHR
I'm pretty sure it's the coil pack because that's what governs sparks and paths. The fuel pump probably isn't the problem because your car starts.
Old Apr 10, 2007 | 11:02 AM
SM2Miata's Avatar
Remember, also. That when the coil pack goes, it will most likly take the O2 and cats with it. Sorry for the bad news.
Doggyx
Aug 11, 2022 08:49 PM
Max 260
Mar 10, 2018 09:39 PM
rednek
Jan 28, 2008 04:16 PM
knelson
Jul 25, 2006 05:04 PM
Izzie_g
Sep 19, 2005 10:55 PM
