1990 engine swap
Hi all unfortunately for me I have a 1990 miata with a bad crank and have tried the repairs without any lomg term sucess. I am now going to find a newer engine. Does anyone know if a 323 1.6litre is the same or should I be looking for a actual used miata engine. thanks all!!
RE: 1990 engine swap
If I was you, I would drop the 1.8L in there. But the 323 motor would be less HP anf torque.
i say just do the 302 small block swap. that will give you a thrill
good luck shoe-horning that into that little engine bay...
altho i have seen a corvette engine swapped into a pontiac solstice... |
Monster Miata has a 302V8 kit. It's being built on the ESPN2 show Gearz.
http://www.monstermiata.com/ I think it would be totally worth it. |
