TCS and handbrake light depending on curves
Old Oct 14, 2018 | 10:42 AM
Marco2G's Avatar
Default TCS and handbrake light depending on curves
Hello everyone
For a few days now my CX-9 has the TCS OFF and handbrake light burning intermittently. I noticed yesterday that it turned on and off depending on driving around corners and curves. Left turns off and right on.
In the evening, it was on almost permanently. I went around a roundabout the whole way and it again turned off albeit only for a short while.
So I would assume this is some kind of loose connection.
Does anyone have an idea where to start looking? A OBD2 bluetooth dongle is on the way but if anyone has a tip on some possible easy fixes to try and rule out, that would be appreciated too.
Regards and thanks,
Marco
Old May 8, 2021 | 01:13 PM
marquina67's Avatar
Default Handbrake Light
Hi Marco, my 2016 cx9 has a similar problem; i activate handbrake, then release, and the handbrake indicator light on the instrument panel keeps blinking. Overnight, the issue would go away. The shop told me it functions properly but a malfunction on the right rear brake caliper is causing the issue. There was no problem when I brought it to them for brake pads and rotors replacement. I was told the caliper needs replacement. Trying to see if anything similar has been mentioned and would love to save some money. The shop says the part is $280 + about $70 for labor = $350. Any suggestions would be much appreciated.....
As for your issue, I would have it checked and done an estimate on. I don't see much of this type of issue elsewhere.
Thanks,
Marquina67
Old May 8, 2021 | 01:57 PM
wosman's Avatar
Originally Posted by Marco2G
Hello everyone
Regards and thanks,
Marco
You'll need to check for Bad or Failing Yaw Rate Sensor.
https://www.autoblog.com/2016/01/13/...w-rate-sensor/
Hope this will help.
2000smazda
Jun 26, 2024 06:12 PM
Curtis Acree
May 2, 2024 09:29 PM
Aptedern
Jul 19, 2020 06:32 PM
Somadina Fanz
Feb 6, 2015 02:07 PM
indranghimiray
Jul 28, 2010 04:53 AM
