Overheating CX9
Old Sep 12, 2021 | 02:42 PM
Nejicx9's Avatar
Default Overheating CX9
Help been working on this car for weeks. Its overheating and the fans aren't coming on. Coolant flowing back into bottle. Fine when moving. But still.need to fined thus problem Replaced thermostat cylinde head temp sensor and fan control modules. Checked relays and all were good. Its.crazy.....when I tap the fan control modules the fans jump and start spinning but do not stay on even with AC running full. Tried to apply power straight to the fans from battery and that didn't work either. Blockage? Water pump? Head gasket? I don't get it.
Old Dec 4, 2021 | 03:23 PM
winkybil's Avatar
Did the engine overheat? I’m having a hard time believing that coolant mixed with the oil from the water pump failing. Something else must have given way for that to occur. Granted, on these engines the water pump is an internal component of the engine driven by the timing chain, which Nox Vidmate VLC makes it’s replacement much more difficult (and $$$ compared to a “traditional” water pump).
MazdaSilva
May 6, 2011 04:59 PM
mappyskf
Jul 3, 2010 04:26 AM
mayfairman
Dec 13, 2008 12:29 PM
lmm9607
Oct 1, 2008 10:08 PM
moochie44
Nov 26, 2005 11:35 PM
