Coolant leaks at cylinder head - Warrant extended
Old Dec 29, 2024 | 12:44 PM
MNJack's Avatar
Default Coolant leaks at cylinder head - Warrant extended
(That should be WARRANTY extended - hate it when that happens!)
Just got a letter from Mazda advising me that they have extended the powertrain warranty to 10 years or 120,000 miles for this issue: "coolant leaks at the cylinder head around the exhaust manifold."
Fortunately, our 2016 CX-9 Touring has not had this issue, and with 220,000 miles is well outside the extended warranty. But good to know anyway.
Last edited by MNJack; Dec 29, 2024 at 12:47 PM. Reason: can't edit error in title - warranty
Old Dec 31, 2024 | 06:38 AM
Bigmac51's Avatar
Default Oil Changes?
I'm curious as to how often you have oil changes performed. I have a 2020 Mazda 6 with 36K and so far no issues. I regularly have the oil changed every 3K.
Old Dec 31, 2024 | 10:19 AM
The intervals in changing the oil has no effluence in the problem noted in the first response.
I would stick by your oil service miles between 3-5 k !
Best advise if you ever have a concern and still under WARRANTY go to your dealer with your questions so it will, or they should log the info in your VIN history in the unluckily event something happens in the future.
Keep in mind all of these forum never post the actual effected numbers and seldom if even do the auto manufactures. On forums because of crossover of information they are often always exaggerated and the information inflated in narrative by members.
Old Dec 31, 2024 | 01:50 PM
MNJack's Avatar
Synthetic oil, so 6k miles or once every year. Car is driven regularly but no longer high miles, so lately it's been once per year.
Old Dec 31, 2024 | 02:09 PM
Maybe give the brand Oil and Viscosity . Also full or semi synthetic?
These actually can matter when answering a question about what is used?
Old Jan 9, 2025 | 08:48 AM
ds235687129's Avatar
Received letter as well.
Old Jan 9, 2025 | 08:54 AM
For all that read this and received the notice
If you received the same notice posted earlier, I am assuming that all that read and understand it ? It does state that you have an issue. It does state that your Mazda must be confirmed to have the issue and then follow the procedure to get the extended warranty. It also does not state in any way that if additional parts and other issues are found that it is covered or will be paid for by Mazda.
It is only a mor or less Heads letter that you may be covered should the described issue happen.
I suggest that the best information and understanding what that letter means instead on Mazda forums should contact directly Customer Experience Center, Mazda North American Operations
edscx-9
Sep 16, 2025 05:27 PM
PhilRich
Oct 25, 2017 07:40 PM
geoffmalter
Nov 22, 2008 03:42 PM
Happy31
Mar 11, 2008 07:28 PM
Whitesnake
Oct 24, 2007 10:41 AM
