2016 CX-9 Engine Compatability
Old Aug 8, 2023 | 11:07 AM
bdc1989's Avatar
Default 2016 CX-9 Engine Compatability
My wife's 2016 CX-9 has the dreaded cracked head. For some reason, while all the part numbers that I can find are the same through 2021 (and probably 2022) for the block, head, cams, lifters, head gasket, exhaust manifold, ECM, ignition system, emissions system, etc., Mazda has a different part number for the long block for 2018-2022 than 2016-2017. I couldn't find a single different part number for the engine itself. About the only part difference I could find in the electrical system remotely related to the engine was one of the two AWD modules has a different part number. The rest of the engine-related electrical is the same. The transmission is the same.
Does anyone know if a 2021 engine will work fine in the 2016? The long block and short block are on backorder. I found a low mileage I'd use if it works.
Thanks
Tyler Guthrie
Apr 21, 2020 08:50 PM
tractionlife
Nov 24, 2016 11:26 PM
trev0006
Jul 24, 2016 04:46 PM
matrix
Jul 23, 2016 09:07 AM
trev0006
Nov 26, 2015 05:24 AM
