2008 CX-9 Clock Reset
Old Mar 5, 2019 | 07:52 PM
JIntorcio's Avatar
Default 2008 CX-9 Clock Reset
Changed out the battery and now can't reset the clock! The clock reset screen shows the 12/24 hr option and the +1 and -1 buttons - but there's no time in the box to adjust? Anyone familiar with a trick to get the clock reset?
Old Mar 6, 2019 | 04:02 AM
Do you have Sat Nav? if so, you will drive the vehicle until it picks up GPS data & auto sets the clock.
If you don't have GPS, can you post a photo of your stereo?
Old Mar 6, 2019 | 07:41 AM
JIntorcio's Avatar
Thanks. We DO have GPS Nav and I thought that was supposed to happen. But it's been a couple of weeks? Had to have acquired signal by now?
Old Mar 10, 2019 | 12:25 PM
Renate Herod's Avatar
Default Same clock problem!
I have been driving around with it wrong for months and it has not reset.. Please let me know if you found a way to fix this. The dealer wants $175 to look at it but says he has never seen the problem before. The clock now says 7:27 when it is actually 12:15. Thanks!
Old Mar 15, 2019 | 07:48 AM
JIntorcio's Avatar
Still no solution. I've tried re-disconnecting the battery and reconnecting both negative first and positive first. Nothing. The navigation system obviously knows what time it is because it can calculate position. It's just not getting to the clock on either the dash or on the GPS display. Flummoxed.
Old Mar 15, 2019 | 09:05 AM
Default Same
I also tried re- disconnecting the battery. Also looked for any blown fuses. But our situation seems to be exactly the same. The GPS works for my car's navigation - just not the clock. If I take it into the dealer or figure it out I will let you know on this thread. Good luck!
Old Apr 15, 2019 | 11:29 AM
DFurdas's Avatar
I have the exact same issue with my clock after disconnecting the battery to work on my trailer wiring harness. The clock has not reset yet. Still trying to figure it out. I drive a 2008 CX-9 Grand Touring.
Old Apr 24, 2019 | 06:38 PM
Adt's Avatar
Adt
Default Clock won't reset by GPS or manually
I changed the battery. Now my clock won't reset by GPS or manually. So frustrated. Have you found a solution?
Old Apr 26, 2019 | 07:41 PM
DFurdas's Avatar
Ugh, no solution yet Adt. I refuse to let the dealership charge me for investigating so my clock remains inaccurate.
Old Apr 30, 2019 | 10:24 AM
Billy Parkhill's Avatar
Has anyone been able to get the issue with the clock fixed yet? Same problem here. Replaced the battery yesterday and can't adjust the clock in the NAV. The GPS is apparently working because I can see where I am on the map. Please Help
