P0300/P0401, rough idle and CEL
Old Oct 10, 2018 | 07:38 AM
WMR08's Avatar
Default P0300/P0401, rough idle and CEL
I'm sure I'm resurrecting a common thread here but would like any advice regarding a CEL with a P0300 and P0401 code. I have replaced the spark plugs and ignition coils with no change. I unplugged the EGR valve to see if that would make a difference before I take it off to try cleaning it. Still have a rough idle going. Runs OK once it's going but idles rough and seems to possibly experience a bit of a power loss. If you have an answer as to what this could be other than these components I mentioned, a description or picture of the problem child part in question would be helpful. I'm fairly new to the Mazda experience. 2008 CX-7 is the car. Thank you...
Old Oct 10, 2018 | 10:02 AM
Arkainzeye's Avatar
P0300 MAZDA - Random Cylinder Misfire Detected
Possible causes Faulty spark plug (s) Faulty ignition coil (s
) Clogged or faulty fuel injector (s)
Intake air leak Fuel injectors harness is open or shorted
Fuel Injectors circuit poor electrical connection
Ignition coils harness is open or shorted
Ignition coils circuit poor electrical connection
Insufficient cylinders compression
Incorrect fuel pressure
P0401 MAZDA - Exhaust Gas Recirculation Flow Insufficient Detected
Possible causes EGR passage clogged
Faulty EGR Vacuum Modulator Valve
Faulty EGR Valve
Faulty EGR solenoid valve
EGR solenoid valve harness is open or shorted
EGR solenoid valve circuit poor electrical connection
Dead (Weak) battery
Faulty EGR temperature sensor and circuit Exhaust gas leaks
Old Oct 10, 2018 | 10:13 AM
WMR08's Avatar
Thank you for the list. Looks like I’m at least looking down the right rabbit hole. I’ll take the EGR valve off and clean it and try that. A new one looks like it rims over $200. I also put Sea Foam into the gas to clean the injectors. Hopefully that helps. The spark plugs and ignition coils are brand new so I can rule those out. If anyone else has any ideas I’m all ears.
Doggyx
Aug 11, 2022 08:49 PM
imkemfly
Apr 17, 2015 07:58 PM
obijuan65
Oct 10, 2012 03:27 PM
mazdagirl8
Sep 22, 2011 01:30 PM
adrockin
Apr 10, 2008 08:26 AM
