No power to passenger window
***I have done extensive searching on this issue, and I have not been able to find this condition/answer to said condition***
2009 Mazda CX7 GT NO power to passenger window. The lights on the switch AREN'T illuminated Drivers side will not operate the window Passenger side will not operate the window No issues with the other three windows or moon roof. Anyone have any suggestions? The Re-initialization/reset won't work, due to the fact the window is completely inoperable. I have changed the 15a fuse interior, as well as the 20a and 30a in the engine bay. |
Are you getting power to the switches?
Are you getting power to the window motor? |
(Post 162888)
Unless you get inside the door & check the electrical circuits, you are only guessing.
Cx 7 passenger side window not working
Hey Richard I'm having the same problems with my cx 7 I was wondering if you ever fix the problem I been searching for days now I check all wiring connections plugs replace window switches window motor bcm I was thinking about changing fuse boxes but before I go that route I found your thread |
Jokerk20, when operating the drivers switch, are you getting power to the passengers window switch &/or motor?
Yes I'm getting power to both switches I have access to Aldata I have check signal connections grownds most of the stuff that the paper ask me to check I try two different switches on the passenger side and two use ones on the driver side I get to signal going out from the driver side switch no up or down on the passenger side the switch doesn't illuminate i was thinking that's my problem i got another bcm from the junk yard still no luck I check the wires to see if they were broken from somewhere but everything is good so far |
A funny little thing can happen
This is a ford/Mazda thing with the power window. Passenger side. You'll have full power to the switch. Motor and wiring through the passenger side. What happens sometimes or if your battery gets disconnected. Or a surge or whatever. There's a relay built into the drivers side switch. It'll fault out the pass. Window. Start the car. Roll the window down with the passenger control. Hold down on the Sievers side control on the passenger button till you hear a click then pull up on the drivers side passenger button. It'll reset the relay. Could be what your missing. It's on Google. Can't remember 100 percent what button devs/passng to hit all the time
Had to do it twice in the past myself |
Originally Posted by Mazdaboy75
(Post 168479)
Had to do it twice in the past myself Thanks, now I know there a driver relay to passenger switch. I suspect my driver switch is broken. |
