Mazda CX7 Headlight replacement?
Old Jan 10, 2010 | 03:37 PM
tarheel63's Avatar
Default Mazda CX7 Headlight replacement?
Hello I am trying to replace the right front headlight for my cx7 - do you have to go thru the fenderwell as the manual suggests - or do you have any easier alternative. It is 20degrees outside and i need this fixed tonight. please help me tks tarheel63
Old Jan 25, 2012 | 07:58 PM
mattweir's Avatar
I am having the same problem.
Old Jan 26, 2012 | 07:04 AM
tarheel63's Avatar
My suggestion is to take to the dealer if you can.... the first time I tried to fix i broke the fitting that holds the light in place. To replace the whole assembly is over $200.... needless to say i did not replace the assembly... I just keep replacing the bulb. the easiest way i have found is to do this.... blocks the rear wheels, take off the front tire, be sure to use extra support under the frame (DO NOT rely on the jack itself - TOO Dangerous), remove the wheel well cover, slip the boot cover off of the light, carefully turn and remove the bulb fitting - then you can replace the bulb - then reassemble. The little screws that hold in the fender well cover pop in and expand when you return the screw...they can break or you may have to use a flathead screwdriver to pop out... hope all this helps... it is a pain but it saves $40 or so dollars at the dealer.
Old Sep 25, 2013 | 10:04 PM
rodneylynn1977's Avatar
Did you break the assembly? is that part replaceable with out replacing the whole headlight assembly? I just broke mine and I don't know what I am going to do.
Old Feb 26, 2014 | 10:12 AM
dwen188's Avatar
rodneylynn1977, how did you repair the assembly? Mine is also broken and the dealership wants to charge me $875 to replace.
Old Feb 27, 2014 | 04:36 AM
To change the headlight bulb you remove the plastic guard liner and access the bulb from inside the wheel arch.
Old Feb 27, 2014 | 09:44 AM
Since my car was still under warranty, and the service rep didn't tell me the headlight bulb was actually under warranty the dealer decided to replace the headlight assembly for me for free. I did have to pay for $50 in labor, but I was definitely ok with that.
Pays to have a great dealership...
Old Jul 25, 2015 | 09:55 PM
dvanable's Avatar
OK, here's what I did to solve the broken headlight assembly issue:
1. Remove bumper: https://youtu.be/2RrITZSop6E
2. Headlight Assembly removal: https://www.youtube.com/watch?v=radfd9Xtucg
Text version: How To: Mazda 6 Front Bumper Removal First Gen | Happy Wrenching
THEN, I took the assembly over to the local auto body guys, who know which epoxy to use for the thermoplastic that the little part which breaks... $25 later, I had a working headlight assembly and reinstalled.
Posting here to help others, and to ideally get Mazda to reduce the price of their parts. Even the aftermarket guys are very expensive...
Good luck, Dave
kimpetit
Aug 21, 2021 05:53 AM
gregbeyer
Feb 10, 2014 07:59 AM
Nav007
Dec 4, 2013 05:29 AM
Almaz
Sep 3, 2012 01:51 AM
justng11
Aug 24, 2011 09:46 AM
