loud engine
Hello All,
I have a 2010 CX-7 with 47K miles. It seems to be very loud compared to when I bought it. There is no problem mechanically. The Dealer has not been able to identify any issues, but it's loud. Has anyone experienced anything like this, if so what was the solution. Thanks very much.
It's a s Touring turbo 4dr Front-wheel Drive 244-hp, 2.3-liter I-4 (premium) 6-speed automatic w/OD and auto-manual Front-wheel Drive.
There is no noise when cold or idle.
There is a wheezing noise when I first accelerate, I also hear it when I pull in to park, as if the power steering is wheezing (similar sound to when you turn the wheel all the way to either end and it can't go any more)
The loud engine noise is every time I accelerate and keep the car going above 40mph.
I just know that the car was not this loud before 40,000 miles. Perhaps it's the turbo? I took it to the dealer last year 2.5K miles ago and changed my injectors, they were clogged.
I had the engine cover changed, the seal was leaking. But the loud engine/turbo noise was there before the work was done.
There is no engine light, no leaks. I'm not sure if this may be exhaust, some hose is loose?
Perhaps you experienced this?
Thanks in advance.
Thanks in advance.
