Latest CX7 re Flash 4/08
The latest reflash for CX7 from 4/08.
It fix’s lean conditon that cause’s turbo to get excessively hot, then heat soak back to block on shut down, causing overheating and possible turbo damage.
Part No. L33P-18881-T, File Name SW-L33PET000
[/align]
SW-L33PET000 = http://www.accessecu.com/accessport/...208%20CDFP.pdf
[/align]
[/align]
[/align]
I am now officially 86'd from my only dealer within 200 miles, Robberson Ford Mazda in Bend, OR !
Even after always being nice and courteous to them, always.
The Idea here is that if you never come in for scheduled service (lost income for them), have many warranty issues, that the formula tells them your a bad investment and once your 36k warranty is expired, your HISTORY buddy. And Mazda can do nothing about it. This is why manufacturers hate the dealer network so much.
I own two newer Mazda's. Never again.
PS the dealer is refusing to fix the fuel pump even though it's still a warranty item under the 60k warranty. They are denying I ever brought up a symtom for this issue! Ha.[/align][/align]Here's the text of the TSB[/align][/align]
Page 1 of 6
CONSUMER NOTICE
: The information and instructions in this bulletin are intended for use by skilled technicians. Mazda technicians utilize the proper tools/
equipment and take training to correctly and safely maintain Mazda vehicles. These instructions should not be performed by “do-it-yourselfers.” Customers
should not assume this bulletin applies to their vehicle or that their vehicle will develop the described concern. To determine if the information applies,
customers should contact their nearest authorized Mazda dealership. Mazda North American Operations reserves the right to alter the specifications and
contents of this bulletin without obligation or advance notice. All rights reserved. No part of this bulletin may be reproduced in any form or by any means,
electronic or mechanical-including photocopying and recording and the use of any kind of information storage and retrieval system -without permission in
writing.
© 2008 Mazda Motor of America, Inc.
Subject:
ROUGH IDLE, LACK OF POWER, AND/OR MIL ON WITH DTC P2177/P2187 (FUEL
SYSTEM LEAN)
Bulletin No:
01-022/08
Last Issued:
04/02/2008
Service Bulletin
Irvine, CA 92618-2922
MULTI-MODEL- ROUGH IDLE, LACK OF POWER, AND/OR MIL ON WITH DTC P2177/P2187 (FUEL SYSTEM
LEAN)
BULLETIN NOTE
This bulletin supersedes the previous bulletin issued on 03/27/08. The REPAIR PROCEDURE has been
revised.
APPLICABLE MODEL(S)/VINS
2007-2008 Mazdaspeed3 vehicles with VINs lower than JM1BK**** ** 859606 (produced before November 22,
2007)
2006-2007 Mazdaspeed6 vehicles
2007-2008 CX-7 vehicles with VINs lower than JM3ER**** ** 196510 (produced before November 19, 2007)
DESCRIPTION
Due to low fuel pressure at the high-pressure fuel pump, some vehicles may experience the following:
• Rough idle, stall, and/or hesitation under cold conditions.
• Intermittent lack of power during acceleration when the engine gets hot.
• MIL turns on with DTC P2177/P2187 (fuel system too lean at off idle).
This is caused by a delayed fuel pressure build-up from the high pressure fuel pump. There are two main reasons
for this:
1. The drive current from the PCM is not enough for some fuel pumps.
2. Some fuel pumps have slower response.
To fix the problem, the PCM software and the specification of the high-pressure fuel pump have been changed.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
1. Reboot the IDS to clear memory before reprogramming.
2. Using IDS 51.9 or later software, reprogram the PCM to the latest calibration (refer to “Calibration Information”
table) by following the “Module Reprogramming” procedure.
NOTE:
• Always update the IDS tool first, then follow on-screen instructions to download the needed calibration
file for PCM reprogramming.
• It is not necessary to remove any fuses or relays during PCM reprogramming when the IDS
screen prompts you to do so. You may accidentally stop power to one of the PCM terminals and
cause the PCM to be blanked, or you may receive error messages during the IDS reprogramming
procedure.
Bulletin No:
01-022/08
Last Issued:
04/02/2008
Page 2 of 6
• IDS shows the calibration part numbers after programming the PCM.
• Please be aware that PCM calibration part numbers and file names listed in any Service Bulletin
may change due to future releases of IDS software, and additional revisions made to those calibrations
for service related concerns.
• When reprogramming a PCM, IDS will always display the “latest” calibration P/N available for
that vehicle. If any calibration has been revised/updated to contain new information for a new
service concern/issue, it will also contain all previously released calibrations.
When performing this procedure, we recommend that a battery charger be installed on
the vehicle battery and turned ON to a maximum charge of no more than 20 AMPS to
keep the vehicle battery up to capacity. If you exceed 20 AMPS, it could damage the VCM.
3. For vehicles built before April 7, 2007 that are experiencing the conditions as noted in this service bulletin
after the PCM calibration update, perform a Warranty Vehicle Inquiry using your eMDCS System and
inspect Warranty Claim Inquiry Detail for high-pressure fuel pump replacement.
• If no prior history of replacement, replace the high-pressure fuel pump. Refer to MS3 online instructions
or Workshop Manual section 01-14 FUEL PUMP UNIT REMOVAL/INSTALLATION.
• If the history indicates part number L3K9-13-35ZB was used during a repair, use the following illustration
to inspect the production date of the high-pressure fuel pump. Replace it if the production date is before
March 26, 2007.
Date of production is marked as a 4 digit code “YMDD” at the pipe.
Y for Year 4 for 2004....7 for 2007
M for Month 1 for Jan....9 for Sept, X for October, Y for Nov, Z for Dec
DD for Date 01 for 1st of month....31 for 31st of month
Example “4Z16” means Dec 16, 2004; 7608 means June 8, 2007
Bulletin No:
01-022/08
Last Issued:
04/02/2008
Page 3 of 6
CAUTION:
When replacing the high-pressure fuel pump, it is very important to make sure that the tension
collar is present before reinstalling the pump. Failure to do so will result in excessive engine
noise and the subsequent failure of the high-pressure fuel pump and its cam lobes.
4. After performing the PCM reprogramming procedure, verify the repair by starting the engine and making
sure there are no MIL illumination or abnormal warning lights present.
NOTE:
• If any DTCs should remain after performing DTC erase, diagnose the DTCs according to the
appropriate Troubleshooting section of the Workshop Manual.
• After PCM reprogramming, it is no longer necessary to road test the vehicle to “relearn” KAM
(Keep Alive Memory).
5. Fill out an “Authorized Modifications” label (P/N 9999-95-AMDC-97) with the new PCM calibration information,
your dealer code, and today’s date.
AUTHORIZED MODIFICATIONS
THESE MODIFICATIONS HAVE BEEN APPROVED, AS APPROPRIATE,
BY THE EPA AND CARB.
THE FOLLOWING MODIFICATIONS HAVE BEEN MADE:
1326c
Bulletin No:
01-022/08
Last Issued:
04/02/2008
Page 4 of 6
6. Place the “Authorized Modifications” label on the “A” pillar below the tear tag in the driver door jamb.
CALIBRATION INFORMATION
Mazdaspeed3 (52.2 or later software)
Mazdaspeed6 (51.9, 52.2 or later software)
Spec New PCM Calibration Part Number File Name
CA L39R-18-881D SW-L39RED000
Fed, Canada L39S-18-881D SW-L39SED000
CA L38G-18-1881G SW-L38JEG000
Fed/Canada L38K-18-1881G SW-L38KEG000
1326d
BDD3
Bulletin No:
01-022/08
Last Issued:
04/02/2008
Page 5 of 6
CX-7 (51.9, 52.2, or later software)
(*): TI-110/07 (Engine Pinging and/or Lack of Power During Acceleration) applied vehicles.
NOTE:
The PCM Calibration Part Numbers listed above are provided for PCM reprogramming purposes only.
These are not necessarily the same Mazda part numbers used to order an actual PCM through the
Mazda Parts System. It is not necessary to order a PCM as part of this repair procedure.
PART(S) INFORMATION
Spec Model Year Drive New PCM Calibration Part Number File Name
CA 2008 2WD L39L-18-881D SW-L39LED000
4WD L39M-18-881D SW-L39MED000
2007 2WD L33L-18-881T SW-L33LET000
2WD(*) LKYX-18-881B SW-LKYXEB000
4WD L33M-18-881T SW-L33MET000
4WD(*) LKYZ-18-881B SW-LKYZEB000
Fed/Canada 2008 2WD L39N-18-881D SW-L39NED000
4WD L39P-18-881D SW-L39PED000
2007 2WD L33N-18-881T SW-L33NET000
2WD(*) LKZ1-18-881B SW-LKZ1EB000
4WD L33P-18-881T SW-L33PET000
4WD(*) LKZ2-18-881B SW-LKZ2EB000
Mexico 2007 2WD L39J-18-881F SW-L39JEF000
4WD L39K-18-881F SW-L39KEF000
Part Number Description Qty. Note
L3K9-13-35ZC Pump, Fuel 1 A new part can be used in place of the former part, but
the former part cannot be used in place of the new part.
Bulletin No:
01-022/08
Last Issued:
04/02/2008
Page 6 of 6
WARRANTY INFORMATION
NOTE:
• This warranty information applies only to verified customer complaints on vehicles eligible for warranty
repair. Refer to the Warranty Wizard for warranty term information.
• Additional diagnostic time cannot be claimed for this repair.
PCM Reprogram Only PCM Reprogram and Fuel Pump
Replacement
Warranty Type A A
Symptom Code 08 08
Damage Code 9W 9W
Part Number Main Cause 5555-08-007A L3K9-13-35ZC
Quantity 0 1
Operation Number / Labor Hours XXC5RXFX / 0.3 Hrs. XXC5RXRX / 1.7 Hrs. (Mazdaspeed3);
1.2 Hrs. (Mazdaspeed6); 1.4 Hrs. (CX-7)[/align]
