CX 7 and fuel efficiency
Old Jan 6, 2009 | 10:03 AM
  #21
wwest's Avatar
Default RE: CX 7 and fuel efficiency
Were I an owner I would improve FE by....
A) "Wiring" the wastegate fully open.
B) Milling the head to get a standard "non-boost" DFI compression ratio of 12:1
C) Design a mod that kept the wastegate fully open except at WOT or with a quick/rapid depression of the gas pedal, sort of a reverse implemenation of BA, Braking Assist. (Not compatible with "B")
D) Design a variable intake valve delay (Atkinson Cycle Engine) such that a 12:1 "off-turbo" compression ratio could be used and then switch back to 10:1 as the turbo is allowed to come online, boost rises.
Note: CAI & BOV are only for those with "boy-racer" mentality and are typically, like K&N, are simply "snake oil" for those that are most gullible.
Old Jan 6, 2009 | 01:00 PM
  #22
Alpha Wolf's Avatar
ORIGINAL: wwest
Funny guy you should actually mount them on a car and drive it before you start providing bad information to others.
I have both and a larger TMIC as well. As I remove these prior to dealer visits I can honestly say you are full of it. There is such a difference in the power, responsiveness and top end power with these mods over stock.
With them I can bark all 4 tires with my AWD touring leaving the line. Try doing that stock
Old Jan 6, 2009 | 06:06 PM
  #23
wwest's Avatar
ORIGINAL: Alpha Wolf
ORIGINAL: wwest
Please note that the title of this thread is "CX-7 and fuel efficiency".I don't think that relates much, if at all, to how much rubber you can lay down on the roadbed. Most likely exactly the opposite.
Old Sep 24, 2009 | 06:19 PM
  #24
tjg's Avatar
tjg
07 awd gt , 15 city , 25 hwy at 70mph
Bobby camaro
Jun 18, 2010 11:00 AM
Shutterbug
Oct 19, 2007 08:30 PM
chunkdude
Jul 11, 2007 07:04 PM
1993mazdaMX6
Mar 31, 2007 11:41 PM
kd5hmy
May 21, 2006 11:46 PM
