Continuous P0303 misfire PLEASE help
Old Aug 5, 2020 | 06:01 AM
Wojtek Wawrzynski's Avatar
Hello James,
How did you go? still with CX 7 or you torched?
I have same problems
Old Aug 6, 2020 | 07:21 AM
luklyz's Avatar
Most likely your injector is plugged and is leaking. Did you check if there is a pressure drop in the rail.
The other option is the high-pressure pump is leaking fuel into the engine.
Both can be fixed. Narazie
Old Aug 10, 2020 | 11:04 PM
Dziekuje for ideas! I will do recondition of injectors first and than pump :-) I had also turbo leaking oil but thanks to your suggestion it all make sense as there is a lot of fuel in oil and oil is too thin... so go through turbo!
Dziekuje! I will update you with results!
Old Nov 27, 2021 | 01:50 AM
DarKing93's Avatar
I had the same issue I changed the fuel filter and the spark plug runs fine now it is back to normal
maryfrancis3
Feb 24, 2019 03:25 AM
gman01Tribute
Jan 15, 2018 04:04 AM
Hatch Kaspar
Jul 21, 2009 11:46 AM
Vaniam
Oct 11, 2008 09:09 PM
bryle
Dec 17, 2007 09:24 AM
