Back up lights quit working 2008 CX 7
Back up light quit working. Is there a fuse I can replace to get them going? If not, where would the backup light switch be located?
Back up switch ( reverse light switch ) Is either a separate switch on the casing of the manual gearbox, or part of the gear position switch on the automatic transmission.
Have you checked & tested the bulbs? |
(Post 200858)
There is no dedicated reverse switch on the auto's - only the manual gearbox.
How did you test the bulbs? Do you have 12v+ & earth at the bulb sockets? |
Cox 7 back up lights
I bought 2 new ones and replace the old ones
I had a backup camera put in my car awhile back. The camera still works/ Is it possible that a wire could have loosened up and disconnected the backup lights?
