Warning Lights
Old Feb 13, 2021 | 04:41 PM
Mike Ouellette's Avatar
Default Warning Lights
I have a 2018 CX5. Got in it today and started it up only to have 3 warning lights on. I had it out earlier today with no issues. See attached. Any ideas?
Old Feb 13, 2021 | 05:44 PM
bobm's Avatar
I'm sure others will chime in, but in the meantime on this Saturday evening, it may be best and quicker to check out your owner's manual.
Old Feb 13, 2021 | 05:59 PM
GAsierra's Avatar
Exclamation
A couple of those are of the "Stop driving / Contact the Dealer ASAP" type of warnings.
From the 2018 CX-5 owner's manual:
  • AT -- Automatic Transaxle Warning Indication/WarningLight
    • The indication/light illuminates when the transaxle has a problem.
    • CAUTION: If the automatic transaxle warning indication/light illuminates, the transaxle has an electrical problem. Continuing to drive your Mazda in this condition could cause damage to your transaxle. Consult an Authorized Mazda Dealer as soon as possible
  • CEL -- Check Engine Light
    • If this light illuminates while driving, the vehicle may have a problem. It is important to note the driving conditions when the light illuminated and consult an Authorized Mazda Dealer.The check engine light may illuminate in the following cases:•The fuel tank level being very low or approaching empty.•The engine's electrical system has a problem.•The emission control system has a problem.•(Except SKYACTIV-D 2.2)•The fuel-filler cap is missing or not tightened securely.
    • If the check engine light remains on, or it flashes continuously , do not drive at high speeds and consult an Authorized Mazda Dealer as soon as possible.
    • WARNING: If the check engine light turns on, do not disconnect the battery cables.If the battery cables are disconnected and then reconnected, the engine could be damaged and catch on fire.
  • TSC/DSC -- (Turns on) TCS/DSC Indicator Light
    • If the light stays on, the TCS, DSC or the brake assist system may have a malfunction and they may not operate correctly. Take your vehicle to an Authorized Mazda Dealer.
Cotheco
Jul 31, 2018 03:01 AM
rodneylynn1977
May 30, 2012 06:08 PM
jjfrisk
Jul 24, 2011 08:52 AM
Dewman
Dec 31, 2010 09:02 AM
ssrof
Mar 18, 2006 04:53 AM
